Time Before: 0.01023 seconds
Time After: 0.01392 seconds
Time Taken: 0.00370 seconds
Time Before: 0.01401 seconds
Time After: 0.01448 seconds
Time Before: 0.01473 seconds
Time After: 0.01488 seconds
Time Before: 0.01573 seconds
Time After: 0.01812 seconds
Time Taken: 0.00239 seconds
Time Before: 0.01495 seconds
Time After: 0.02266 seconds
Time Taken: 0.00771 seconds
Time Before: 0.02806 seconds
Time After: 0.02848 seconds
Time Before: 0.03167 seconds
Time After: 0.03286 seconds
Time Before: 0.02734 seconds
Time After: 0.03305 seconds
Time Taken: 0.00571 seconds
Time Before: 0.05303 seconds
Time After: 0.05318 seconds
Time Before: 0.06039 seconds
Time After: 0.06164 seconds
Time Before: 0.06715 seconds
Time After: 0.06731 seconds
Time Before: 0.06946 seconds
Time After: 0.07095 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=131518' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.08586 seconds
Time After: 0.08614 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
