Time Before: 0.00606 seconds
Time After: 0.00761 seconds
Time Taken: 0.00154 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.00770 seconds
Time After: 0.00981 seconds
Time Taken: 0.00210 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.01010 seconds
Time After: 0.01031 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.01118 seconds
Time After: 0.01365 seconds
Time Taken: 0.00248 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.01040 seconds
Time After: 0.01812 seconds
Time Taken: 0.00772 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.02145 seconds
Time After: 0.02188 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.02441 seconds
Time After: 0.02562 seconds
Memory Before: 2,147.414 KB
Memory After: 2,147.273 KB
Time Before: 0.02074 seconds
Time After: 0.02585 seconds
Time Taken: 0.00511 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.641 KB
Memory Used: 133.211 KB
Time Before: 0.03731 seconds
Time After: 0.03763 seconds
Memory Before: 2,814.180 KB
Memory After: 2,814.695 KB
Time Before: 0.04314 seconds
Time After: 0.04447 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,902.500 KB
Memory After: 2,903.094 KB
End call of global.php: 0.046118021011353
Time Before: 0.04886 seconds
Time After: 0.04911 seconds
Memory Before: 3,539.297 KB
Memory After: 3,539.727 KB
Time Before: 0.05107 seconds
Time After: 0.05261 seconds
Memory Before: 3,820.828 KB
Memory After: 3,822.516 KB
SET lastactivity = 1784717403, location = '/forums/private.php?do=newpm&explain=1&u=131624'
Time Before: 0.06554 seconds
Time After: 0.06584 seconds
Memory Before: 4,300.188 KB
Memory After: 4,300.406 KB
Page generated in 0.064646005630493 seconds with 9 queries, spending 0.010168075561523 doing MySQL queries and 0.05447793006897 doing PHP things.
