Time Before: 0.00153 seconds
Time After: 0.00198 seconds
Time Before: 0.00205 seconds
Time After: 0.00248 seconds
Time Before: 0.00269 seconds
Time After: 0.00289 seconds
Time Before: 0.00364 seconds
Time After: 0.00669 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00293 seconds
Time After: 0.01186 seconds
Time Taken: 0.00892 seconds
Time Before: 0.01430 seconds
Time After: 0.01453 seconds
Time Before: 0.01703 seconds
Time After: 0.01826 seconds
Time Before: 0.01350 seconds
Time After: 0.01851 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02529 seconds
Time After: 0.02543 seconds
Time Before: 0.02742 seconds
Time After: 0.02866 seconds
End call of global.php: 0.030426025390625
Time Before: 0.03167 seconds
Time After: 0.03183 seconds
Time Before: 0.03435 seconds
Time After: 0.03583 seconds
SET lastactivity = 1785414619, location = '/forums/private.php?do=newpm&explain=1&u=131642', badlocation = 1
Time Before: 0.05240 seconds
Time After: 0.05270 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
Page generated in 0.051476001739502 seconds with 9 queries, spending 0.0084381103515625 doing MySQL queries and 0.043037891387939 doing PHP things.
