Time Before: 0.00138 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00243 seconds
Time Before: 0.00266 seconds
Time After: 0.00282 seconds
Time Before: 0.00349 seconds
Time After: 0.00635 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00287 seconds
Time After: 0.00978 seconds
Time Taken: 0.00692 seconds
Time Before: 0.01170 seconds
Time After: 0.01205 seconds
Time Before: 0.01457 seconds
Time After: 0.01580 seconds
Time Before: 0.01111 seconds
Time After: 0.01597 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02261 seconds
Time After: 0.02274 seconds
Time Before: 0.02493 seconds
Time After: 0.02617 seconds
End call of global.php: 0.027884006500244
Time Before: 0.02917 seconds
Time After: 0.02938 seconds
Time Before: 0.03148 seconds
Time After: 0.03313 seconds
Time Taken: 0.00165 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=131746'
Time Before: 0.05158 seconds
Time After: 0.05180 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.05026912689209 seconds with 9 queries, spending 0.0085287094116211 doing MySQL queries and 0.041740417480469 doing PHP things.
