Time Before: 0.00170 seconds
Time After: 0.00220 seconds
Time Before: 0.00228 seconds
Time After: 0.00267 seconds
Time Before: 0.00290 seconds
Time After: 0.00304 seconds
Time Before: 0.00397 seconds
Time After: 0.00668 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00313 seconds
Time After: 0.01136 seconds
Time Taken: 0.00824 seconds
Time Before: 0.01355 seconds
Time After: 0.01396 seconds
Time Before: 0.01672 seconds
Time After: 0.01796 seconds
Time Before: 0.01283 seconds
Time After: 0.01821 seconds
Time Taken: 0.00538 seconds
Time Before: 0.02376 seconds
Time After: 0.02406 seconds
Time Before: 0.02587 seconds
Time After: 0.02733 seconds
Time Before: 0.03146 seconds
Time After: 0.03163 seconds
Time Before: 0.03435 seconds
Time After: 0.03587 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1783273617, location = '/forums/private.php?do=newpm&explain=1&u=131756' WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.04903 seconds
Time After: 0.04932 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
