Time Before: 0.01344 seconds
Time After: 0.01783 seconds
Time Taken: 0.00439 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01792 seconds
Time After: 0.01837 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01866 seconds
Time After: 0.01878 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01958 seconds
Time After: 0.02220 seconds
Time Taken: 0.00263 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01885 seconds
Time After: 0.02692 seconds
Time Taken: 0.00807 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03274 seconds
Time After: 0.03329 seconds
Time Taken: 0.00055 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03586 seconds
Time After: 0.03705 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.03203 seconds
Time After: 0.03727 seconds
Time Taken: 0.00524 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.05924 seconds
Time After: 0.05944 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.09546 seconds
Time After: 0.09670 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.098788976669312
Time Before: 0.11618 seconds
Time After: 0.11638 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.12065 seconds
Time After: 0.12208 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=131780', badlocation = 1
WHERE sessionhash = '4107984102e2914075bf6bfb65da9afe'
Time Before: 0.14557 seconds
Time After: 0.14621 seconds
Time Taken: 0.00064 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
Page generated in 0.14435195922852 seconds with 9 queries, spending 0.0086543560028076 doing MySQL queries and 0.13569760322571 doing PHP things.
