Time Before: 0.00131 seconds
Time After: 0.00182 seconds
Time Before: 0.00188 seconds
Time After: 0.00224 seconds
Time Before: 0.00251 seconds
Time After: 0.00272 seconds
Time Before: 0.00350 seconds
Time After: 0.00630 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00279 seconds
Time After: 0.01125 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01308 seconds
Time After: 0.01360 seconds
Time Before: 0.01634 seconds
Time After: 0.01756 seconds
Time Before: 0.01251 seconds
Time After: 0.01775 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02297 seconds
Time After: 0.02313 seconds
Time Before: 0.02500 seconds
Time After: 0.02620 seconds
Time Before: 0.03024 seconds
Time After: 0.03042 seconds
Time Before: 0.03335 seconds
Time After: 0.03502 seconds
Time Taken: 0.00167 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=131785', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04773 seconds
Time After: 0.04799 seconds
