Time Before: 0.00143 seconds
Time After: 0.00194 seconds
Time Before: 0.00201 seconds
Time After: 0.00251 seconds
Time Before: 0.00270 seconds
Time After: 0.00281 seconds
Time Before: 0.00348 seconds
Time After: 0.00565 seconds
Time Taken: 0.00216 seconds
Time Before: 0.00286 seconds
Time After: 0.01123 seconds
Time Taken: 0.00837 seconds
Time Before: 0.01326 seconds
Time After: 0.01368 seconds
Time Before: 0.01571 seconds
Time After: 0.01700 seconds
Time Before: 0.01250 seconds
Time After: 0.01720 seconds
Time Taken: 0.00471 seconds
Time Before: 0.02229 seconds
Time After: 0.02243 seconds
Time Before: 0.02448 seconds
Time After: 0.02569 seconds
End call of global.php: 0.027354001998901
Time Before: 0.02878 seconds
Time After: 0.02892 seconds
Time Before: 0.03096 seconds
Time After: 0.03293 seconds
Time Taken: 0.00197 seconds
SET lastactivity = 1789068016, location = '/forums/private.php?do=newpm&explain=1&u=131787'
Time Before: 0.04544 seconds
Time After: 0.04590 seconds
Page generated in 0.044494867324829 seconds with 9 queries, spending 0.0084061622619629 doing MySQL queries and 0.036088705062866 doing PHP things.
