Time Before: 0.00135 seconds
Time After: 0.00189 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00196 seconds
Time After: 0.00266 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00295 seconds
Time After: 0.00325 seconds
Time Before: 0.00393 seconds
Time After: 0.00640 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00330 seconds
Time After: 0.01065 seconds
Time Taken: 0.00735 seconds
Time Before: 0.01262 seconds
Time After: 0.01306 seconds
Time Before: 0.01450 seconds
Time After: 0.01649 seconds
Time Taken: 0.00199 seconds
Time Before: 0.01204 seconds
Time After: 0.01668 seconds
Time Taken: 0.00464 seconds
Time Before: 0.02340 seconds
Time After: 0.02360 seconds
Time Before: 0.02586 seconds
Time After: 0.02715 seconds
End call of global.php: 0.029687881469727
Time Before: 0.03112 seconds
Time After: 0.03130 seconds
Time Before: 0.03396 seconds
Time After: 0.03551 seconds
Time Taken: 0.00155 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=131829', badlocation = 1
Time Before: 0.04973 seconds
Time After: 0.19054 seconds
Time Taken: 0.14081 seconds
Page generated in 0.048662900924683 seconds with 9 queries, spending 0.14993953704834 doing MySQL queries and -0.10127663612366 doing PHP things.
