Time Before: 0.02154 seconds
Time After: 0.02597 seconds
Time Taken: 0.00443 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02606 seconds
Time After: 0.02672 seconds
Time Taken: 0.00065 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02709 seconds
Time After: 0.02726 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02828 seconds
Time After: 0.03043 seconds
Time Taken: 0.00214 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02734 seconds
Time After: 0.03466 seconds
Time Taken: 0.00732 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04295 seconds
Time After: 0.04333 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04590 seconds
Time After: 0.04714 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.04213 seconds
Time After: 0.04735 seconds
Time Taken: 0.00523 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.10611 seconds
Time After: 0.10628 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.43528 seconds
Time After: 0.43718 seconds
Time Taken: 0.00191 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.47184 seconds
Time After: 0.47201 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.47765 seconds
Time After: 0.47909 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=131835', badlocation = 1 WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.51098 seconds
Time After: 0.51130 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
