Time Before: 0.00334 seconds
Time After: 0.00461 seconds
Time Before: 0.00473 seconds
Time After: 0.00540 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00568 seconds
Time After: 0.00584 seconds
Time Before: 0.00680 seconds
Time After: 0.00922 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00591 seconds
Time After: 0.01392 seconds
Time Taken: 0.00801 seconds
Time Before: 0.01703 seconds
Time After: 0.01748 seconds
Time Before: 0.02049 seconds
Time After: 0.02176 seconds
Time Before: 0.01620 seconds
Time After: 0.02203 seconds
Time Taken: 0.00583 seconds
Time Before: 0.02755 seconds
Time After: 0.02771 seconds
Time Before: 0.03065 seconds
Time After: 0.03190 seconds
Time Before: 0.03534 seconds
Time After: 0.03552 seconds
Time Before: 0.03863 seconds
Time After: 0.04021 seconds
Time Taken: 0.00158 seconds
UPDATE session SET lastactivity = 1788878207, location = '/forums/private.php?do=newpm&explain=1&u=131847' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05472 seconds
Time After: 0.05516 seconds
