Time Before: 0.00136 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00274 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00307 seconds
Time After: 0.00327 seconds
Time Before: 0.00411 seconds
Time After: 0.00671 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00336 seconds
Time After: 0.01014 seconds
Time Taken: 0.00678 seconds
Time Before: 0.01220 seconds
Time After: 0.01262 seconds
Time Before: 0.01413 seconds
Time After: 0.01538 seconds
Time Before: 0.01161 seconds
Time After: 0.01568 seconds
Time Taken: 0.00407 seconds
Time Before: 0.02310 seconds
Time After: 0.02330 seconds
Time Before: 0.02518 seconds
Time After: 0.02638 seconds
End call of global.php: 0.028187036514282
Time Before: 0.02953 seconds
Time After: 0.02967 seconds
Time Before: 0.03180 seconds
Time After: 0.03324 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=132072'
Time Before: 0.04804 seconds
Time After: 0.04828 seconds
Page generated in 0.046970844268799 seconds with 9 queries, spending 0.0084888935089111 doing MySQL queries and 0.038481950759888 doing PHP things.
