Time Before: 0.00175 seconds
Time After: 0.00230 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00238 seconds
Time After: 0.00283 seconds
Time Before: 0.00307 seconds
Time After: 0.00352 seconds
Time Before: 0.00430 seconds
Time After: 0.00704 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00357 seconds
Time After: 0.01114 seconds
Time Taken: 0.00757 seconds
Time Before: 0.01392 seconds
Time After: 0.01437 seconds
Time Before: 0.01608 seconds
Time After: 0.01738 seconds
Time Before: 0.01315 seconds
Time After: 0.01756 seconds
Time Taken: 0.00440 seconds
Time Before: 0.02277 seconds
Time After: 0.02290 seconds
Time Before: 0.02483 seconds
Time After: 0.02608 seconds
End call of global.php: 0.028452157974243
Time Before: 0.02991 seconds
Time After: 0.03006 seconds
Time Before: 0.03252 seconds
Time After: 0.03393 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=132151', badlocation = 1
Time Before: 0.04630 seconds
Time After: 0.04660 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.045406103134155 seconds with 9 queries, spending 0.0086193084716797 doing MySQL queries and 0.036786794662476 doing PHP things.
