Time Before: 0.02537 seconds
Time After: 0.03144 seconds
Time Taken: 0.00607 seconds
Time Before: 0.03153 seconds
Time After: 0.03203 seconds
Time Before: 0.03228 seconds
Time After: 0.03246 seconds
Time Before: 0.03321 seconds
Time After: 0.03559 seconds
Time Taken: 0.00238 seconds
Time Before: 0.03252 seconds
Time After: 0.03957 seconds
Time Taken: 0.00705 seconds
Time Before: 0.05099 seconds
Time After: 0.05121 seconds
Time Before: 0.05430 seconds
Time After: 0.05551 seconds
Time Before: 0.05025 seconds
Time After: 0.05570 seconds
Time Taken: 0.00545 seconds
Time Before: 0.09498 seconds
Time After: 0.09535 seconds
Time Before: 0.11561 seconds
Time After: 0.11686 seconds
Time Before: 0.12590 seconds
Time After: 0.12605 seconds
Time Before: 0.12860 seconds
Time After: 0.13006 seconds
UPDATE session SET lastactivity = 1776534812, location = '/forums/private.php?do=newpm&explain=1&u=132153', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.14985 seconds
Time After: 0.15021 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
