Time Before: 0.00198 seconds
Time After: 0.00258 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00268 seconds
Time After: 0.00316 seconds
Time Before: 0.00346 seconds
Time After: 0.00360 seconds
Time Before: 0.00492 seconds
Time After: 0.00837 seconds
Time Taken: 0.00345 seconds
Time Before: 0.00367 seconds
Time After: 0.01175 seconds
Time Taken: 0.00808 seconds
Time Before: 0.01346 seconds
Time After: 0.01386 seconds
Time Before: 0.01686 seconds
Time After: 0.01805 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01288 seconds
Time After: 0.01822 seconds
Time Taken: 0.00534 seconds
Memory After: 2,261.820 KB
Time Before: 0.02335 seconds
Time After: 0.02382 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02611 seconds
Time After: 0.02735 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.02987813949585
Time Before: 0.03175 seconds
Time After: 0.03191 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03394 seconds
Time After: 0.03541 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789082390, location = '/forums/private.php?do=newpm&explain=1&u=132189'
Time Before: 0.04882 seconds
Time After: 0.04928 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.047901153564453 seconds with 9 queries, spending 0.0094389915466309 doing MySQL queries and 0.038462162017822 doing PHP things.
