Time Before: 0.00390 seconds
Time After: 0.00501 seconds
Time Taken: 0.00111 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00515 seconds
Time After: 0.00591 seconds
Time Taken: 0.00076 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00618 seconds
Time After: 0.00633 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00714 seconds
Time After: 0.01030 seconds
Time Taken: 0.00316 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00638 seconds
Time After: 0.01368 seconds
Time Taken: 0.00730 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01579 seconds
Time After: 0.01617 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01852 seconds
Time After: 0.01995 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01516 seconds
Time After: 0.02013 seconds
Time Taken: 0.00497 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02638 seconds
Time After: 0.02655 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03696 seconds
Time After: 0.03839 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.040098905563354
Time Before: 0.04684 seconds
Time After: 0.04708 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04938 seconds
Time After: 0.05086 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=132225'
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.06417 seconds
Time After: 0.06447 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
Page generated in 0.063272953033447 seconds with 9 queries, spending 0.0094873905181885 doing MySQL queries and 0.053785562515259 doing PHP things.
