Time Before: 0.01734 seconds
Time After: 0.02195 seconds
Time Taken: 0.00461 seconds
Time Before: 0.02205 seconds
Time After: 0.02248 seconds
Time Before: 0.02271 seconds
Time After: 0.02286 seconds
Time Before: 0.02364 seconds
Time After: 0.02617 seconds
Time Taken: 0.00253 seconds
Time Before: 0.02292 seconds
Time After: 0.03018 seconds
Time Taken: 0.00726 seconds
Time Before: 0.03585 seconds
Time After: 0.03647 seconds
Time Taken: 0.00061 seconds
Time Before: 0.03928 seconds
Time After: 0.04076 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03505 seconds
Time After: 0.04100 seconds
Time Taken: 0.00596 seconds
Memory After: 2,261.820 KB
Time Before: 0.07320 seconds
Time After: 0.07335 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.08862 seconds
Time After: 0.08990 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.09932 seconds
Time After: 0.09948 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.10186 seconds
Time After: 0.10334 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788952010, location = '/forums/private.php?do=newpm&explain=1&u=132238' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.12211 seconds
Time After: 0.12237 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
