Time Before: 0.00362 seconds
Time After: 0.00451 seconds
Time Taken: 0.00090 seconds
Time Before: 0.00465 seconds
Time After: 0.00511 seconds
Time Before: 0.00540 seconds
Time After: 0.00554 seconds
Time Before: 0.00635 seconds
Time After: 0.00914 seconds
Time Taken: 0.00279 seconds
Time Before: 0.00560 seconds
Time After: 0.01454 seconds
Time Taken: 0.00895 seconds
Time Before: 0.01788 seconds
Time After: 0.01827 seconds
Time Before: 0.01966 seconds
Time After: 0.02086 seconds
Time Before: 0.01687 seconds
Time After: 0.02111 seconds
Time Taken: 0.00424 seconds
Time Before: 0.02886 seconds
Time After: 0.02909 seconds
Time Before: 0.03286 seconds
Time After: 0.03409 seconds
End call of global.php: 0.037000894546509
Time Before: 0.03994 seconds
Time After: 0.04027 seconds
Time Before: 0.04330 seconds
Time After: 0.04481 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=132244', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.06142 seconds
Time After: 0.06171 seconds
Page generated in 0.060483932495117 seconds with 9 queries, spending 0.0085639953613281 doing MySQL queries and 0.051919937133789 doing PHP things.
