Time Before: 0.00653 seconds
Time After: 0.00904 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00914 seconds
Time After: 0.00966 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00996 seconds
Time After: 0.01013 seconds
Time Before: 0.01090 seconds
Time After: 0.01336 seconds
Time Taken: 0.00246 seconds
Time Before: 0.01018 seconds
Time After: 0.01782 seconds
Time Taken: 0.00764 seconds
Time Before: 0.02171 seconds
Time After: 0.02211 seconds
Time Before: 0.02466 seconds
Time After: 0.02594 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.02100 seconds
Time After: 0.02616 seconds
Time Taken: 0.00517 seconds
Memory After: 2,261.703 KB
Time Before: 0.04057 seconds
Time After: 0.04079 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.05063 seconds
Time After: 0.05190 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.054327964782715
Time Before: 0.05910 seconds
Time After: 0.05926 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.06150 seconds
Time After: 0.06298 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=132251', badlocation = 1
Time Before: 0.08113 seconds
Time After: 0.08140 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.079992055892944 seconds with 9 queries, spending 0.0082340240478516 doing MySQL queries and 0.071758031845093 doing PHP things.
