Time Before: 0.02739 seconds
Time After: 0.03522 seconds
Time Taken: 0.00783 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03531 seconds
Time After: 0.03586 seconds
Time Taken: 0.00055 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03608 seconds
Time After: 0.03621 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03702 seconds
Time After: 0.03893 seconds
Time Taken: 0.00191 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03627 seconds
Time After: 0.04340 seconds
Time Taken: 0.00713 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.05070 seconds
Time After: 0.05115 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05432 seconds
Time After: 0.05561 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04999 seconds
Time After: 0.05584 seconds
Time Taken: 0.00584 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.10896 seconds
Time After: 0.10912 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.19515 seconds
Time After: 0.19653 seconds
Time Taken: 0.00139 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.19868898391724
Time Before: 0.23385 seconds
Time After: 0.23408 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.23952 seconds
Time After: 0.24096 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1772880736, location = '/forums/private.php?do=newpm&explain=1&u=132253', badlocation = 1
WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.27798 seconds
Time After: 0.27828 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.27650094032288 seconds with 9 queries, spending 0.0078694820404053 doing MySQL queries and 0.26863145828247 doing PHP things.
