Time Before: 0.01008 seconds
Time After: 0.01432 seconds
Time Taken: 0.00424 seconds
Time Before: 0.01443 seconds
Time After: 0.01500 seconds
Time Taken: 0.00057 seconds
Time Before: 0.01522 seconds
Time After: 0.01534 seconds
Time Before: 0.01612 seconds
Time After: 0.01852 seconds
Time Taken: 0.00241 seconds
Time Before: 0.01539 seconds
Time After: 0.02257 seconds
Time Taken: 0.00718 seconds
Time Before: 0.03081 seconds
Time After: 0.03120 seconds
Time Before: 0.03380 seconds
Time After: 0.03498 seconds
Time Taken: 0.00118 seconds
Time Before: 0.03002 seconds
Time After: 0.03523 seconds
Time Taken: 0.00521 seconds
Time Before: 0.05534 seconds
Time After: 0.05551 seconds
Time Before: 0.06678 seconds
Time After: 0.06805 seconds
End call of global.php: 0.070703029632568
Time Before: 0.07705 seconds
Time After: 0.07722 seconds
Time Before: 0.08001 seconds
Time After: 0.08146 seconds
SET lastactivity = 1785352794, location = '/forums/private.php?do=newpm&explain=1&u=132270'
Time Before: 0.09966 seconds
Time After: 0.09999 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.098435163497925 seconds with 9 queries, spending 0.0080657005310059 doing MySQL queries and 0.090369462966919 doing PHP things.
