Time Before: 0.00212 seconds
Time After: 0.00297 seconds
Time Taken: 0.00085 seconds
Time Before: 0.00307 seconds
Time After: 0.00350 seconds
Time Before: 0.00375 seconds
Time After: 0.00391 seconds
Time Before: 0.00461 seconds
Time After: 0.00709 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00397 seconds
Time After: 0.01050 seconds
Time Taken: 0.00653 seconds
Time Before: 0.01264 seconds
Time After: 0.01308 seconds
Time Before: 0.01557 seconds
Time After: 0.01698 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01163 seconds
Time After: 0.01715 seconds
Time Taken: 0.00553 seconds
Memory After: 2,261.703 KB
Time Before: 0.02227 seconds
Time After: 0.02251 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02632 seconds
Time After: 0.02760 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.029197931289673
Time Before: 0.03048 seconds
Time After: 0.03064 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03255 seconds
Time After: 0.03397 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=132340'
Time Before: 0.04613 seconds
Time After: 0.04635 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.04524302482605 seconds with 9 queries, spending 0.0082435607910156 doing MySQL queries and 0.036999464035034 doing PHP things.
