Time Before: 0.00140 seconds
Time After: 0.00186 seconds
Time Before: 0.00194 seconds
Time After: 0.00286 seconds
Time Taken: 0.00092 seconds
Time Before: 0.00308 seconds
Time After: 0.00324 seconds
Time Before: 0.00397 seconds
Time After: 0.00642 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00329 seconds
Time After: 0.00985 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01179 seconds
Time After: 0.01224 seconds
Time Before: 0.01475 seconds
Time After: 0.01601 seconds
Time Before: 0.01115 seconds
Time After: 0.01619 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02135 seconds
Time After: 0.02158 seconds
Time Before: 0.02340 seconds
Time After: 0.02466 seconds
End call of global.php: 0.026370048522949
Time Before: 0.02787 seconds
Time After: 0.02811 seconds
Time Before: 0.03008 seconds
Time After: 0.03161 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1789062131, location = '/forums/private.php?do=newpm&explain=1&u=132423', badlocation = 1
Time Before: 0.04418 seconds
Time After: 0.04461 seconds
Page generated in 0.043282032012939 seconds with 9 queries, spending 0.0089316368103027 doing MySQL queries and 0.034350395202637 doing PHP things.
