Time Before: 0.02104 seconds
Time After: 0.02490 seconds
Time Taken: 0.00386 seconds
Time Before: 0.02500 seconds
Time After: 0.02540 seconds
Time Before: 0.02565 seconds
Time After: 0.02578 seconds
Time Before: 0.02655 seconds
Time After: 0.02915 seconds
Time Taken: 0.00260 seconds
Time Before: 0.02586 seconds
Time After: 0.03347 seconds
Time Taken: 0.00762 seconds
Time Before: 0.03916 seconds
Time After: 0.03940 seconds
Time Before: 0.04222 seconds
Time After: 0.04370 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03842 seconds
Time After: 0.04394 seconds
Time Taken: 0.00552 seconds
Memory After: 2,261.820 KB
Time Before: 0.06872 seconds
Time After: 0.06885 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 2.40317 seconds
Time After: 2.40482 seconds
Time Taken: 0.00166 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 2.4078109264374
Time Before: 2.41870 seconds
Time After: 2.41888 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 2.42218 seconds
Time After: 2.42367 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788949208, location = '/forums/private.php?do=newpm&explain=1&u=132435'
Time Before: 2.44491 seconds
Time After: 2.44518 seconds
Memory Before: 4,288.359 KB
Memory After: 4,288.586 KB
Page generated in 2.443482875824 seconds with 9 queries, spending 0.0085723400115967 doing MySQL queries and 2.4349105358124 doing PHP things.
