Time Before: 0.00165 seconds
Time After: 0.00230 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00237 seconds
Time After: 0.00280 seconds
Time Before: 0.00305 seconds
Time After: 0.00324 seconds
Time Before: 0.00392 seconds
Time After: 0.00728 seconds
Time Taken: 0.00336 seconds
Time Before: 0.00330 seconds
Time After: 0.01155 seconds
Time Taken: 0.00825 seconds
Time Before: 0.01384 seconds
Time After: 0.01406 seconds
Time Before: 0.01677 seconds
Time After: 0.01797 seconds
Time Before: 0.01305 seconds
Time After: 0.01823 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02534 seconds
Time After: 0.02552 seconds
Time Before: 0.02803 seconds
Time After: 0.02929 seconds
End call of global.php: 0.032061100006104
Time Before: 0.03349 seconds
Time After: 0.03366 seconds
Time Before: 0.03667 seconds
Time After: 0.03813 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=132483', badlocation = 1
Time Before: 0.05346 seconds
Time After: 0.05389 seconds
Page generated in 0.052289962768555 seconds with 9 queries, spending 0.0089032649993896 doing MySQL queries and 0.043386697769165 doing PHP things.
