Time Before: 0.00175 seconds
Time After: 0.00230 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00238 seconds
Time After: 0.00286 seconds
Time Before: 0.00312 seconds
Time After: 0.00325 seconds
Time Before: 0.00416 seconds
Time After: 0.00790 seconds
Time Taken: 0.00374 seconds
Time Before: 0.00332 seconds
Time After: 0.01131 seconds
Time Taken: 0.00799 seconds
Time Before: 0.01394 seconds
Time After: 0.01436 seconds
Time Before: 0.01701 seconds
Time After: 0.01824 seconds
Time Before: 0.01326 seconds
Time After: 0.01848 seconds
Time Taken: 0.00522 seconds
Time Before: 0.02550 seconds
Time After: 0.02597 seconds
Time Before: 0.02852 seconds
Time After: 0.02990 seconds
Time Taken: 0.00139 seconds
End call of global.php: 0.031564950942993
Time Before: 0.03292 seconds
Time After: 0.03308 seconds
Time Before: 0.03523 seconds
Time After: 0.03679 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1776781231, location = '/forums/private.php?do=newpm&explain=1&u=132505', badlocation = 1
Time Before: 0.05062 seconds
Time After: 0.05098 seconds
Page generated in 0.049712896347046 seconds with 9 queries, spending 0.0099308490753174 doing MySQL queries and 0.039782047271729 doing PHP things.
