Time Before: 0.01919 seconds
Time After: 0.02486 seconds
Time Taken: 0.00567 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.02499 seconds
Time After: 0.02590 seconds
Time Taken: 0.00091 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.02619 seconds
Time After: 0.02633 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.02725 seconds
Time After: 0.02934 seconds
Time Taken: 0.00209 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.02644 seconds
Time After: 0.03366 seconds
Time Taken: 0.00722 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.03989 seconds
Time After: 0.04028 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.04313 seconds
Time After: 0.04429 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.789 KB
Memory After: 2,148.648 KB
Time Before: 0.03915 seconds
Time After: 0.04453 seconds
Time Taken: 0.00538 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.688 KB
Memory Used: 132.781 KB
Time Before: 0.07473 seconds
Time After: 0.07486 seconds
Memory Before: 2,815.211 KB
Memory After: 2,815.727 KB
Time Before: 0.08952 seconds
Time After: 0.09090 seconds
Time Taken: 0.00138 seconds
Memory Before: 2,903.508 KB
Memory After: 2,904.102 KB
End call of global.php: 0.092979907989502
Time Before: 0.09912 seconds
Time After: 0.09928 seconds
Memory Before: 3,540.266 KB
Memory After: 3,540.695 KB
Time Before: 0.10273 seconds
Time After: 0.10424 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,822.000 KB
Memory After: 3,823.688 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=132511'
Time Before: 0.12428 seconds
Time After: 0.12598 seconds
Time Taken: 0.00170 seconds
Memory Before: 4,296.234 KB
Memory After: 4,296.477 KB
Page generated in 0.12327003479004 seconds with 9 queries, spending 0.0095479488372803 doing MySQL queries and 0.11372208595276 doing PHP things.
