Time Before: 0.00151 seconds
Time After: 0.00203 seconds
Time Before: 0.00210 seconds
Time After: 0.00247 seconds
Time Before: 0.00266 seconds
Time After: 0.00280 seconds
Time Before: 0.00347 seconds
Time After: 0.00574 seconds
Time Taken: 0.00227 seconds
Time Before: 0.00285 seconds
Time After: 0.00915 seconds
Time Taken: 0.00630 seconds
Time Before: 0.01141 seconds
Time After: 0.01178 seconds
Time Before: 0.01429 seconds
Time After: 0.01551 seconds
Time Before: 0.01075 seconds
Time After: 0.01570 seconds
Time Taken: 0.00496 seconds
Time Before: 0.02190 seconds
Time After: 0.02210 seconds
Time Before: 0.02410 seconds
Time After: 0.02545 seconds
Time Taken: 0.00134 seconds
Time Before: 0.02843 seconds
Time After: 0.02872 seconds
Time Before: 0.03084 seconds
Time After: 0.03266 seconds
Time Taken: 0.00182 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=132517', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04510 seconds
Time After: 0.04542 seconds
