Time Before: 0.00148 seconds
Time After: 0.00205 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00212 seconds
Time After: 0.00265 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00291 seconds
Time After: 0.00308 seconds
Time Before: 0.00402 seconds
Time After: 0.00669 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00315 seconds
Time After: 0.01143 seconds
Time Taken: 0.00827 seconds
Time Before: 0.01395 seconds
Time After: 0.01432 seconds
Time Before: 0.01577 seconds
Time After: 0.01700 seconds
Time Before: 0.01315 seconds
Time After: 0.01722 seconds
Time Taken: 0.00408 seconds
Time Before: 0.02337 seconds
Time After: 0.02353 seconds
Time Before: 0.02655 seconds
Time After: 0.02790 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.030386924743652
Time Before: 0.03176 seconds
Time After: 0.03192 seconds
Time Before: 0.03496 seconds
Time After: 0.03640 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=132549', badlocation = 1
Time Before: 0.05411 seconds
Time After: 0.05437 seconds
Page generated in 0.053144931793213 seconds with 9 queries, spending 0.008333683013916 doing MySQL queries and 0.044811248779297 doing PHP things.
