Time Before: 0.00161 seconds
Time After: 0.00210 seconds
Time Before: 0.00217 seconds
Time After: 0.00266 seconds
Time Before: 0.00292 seconds
Time After: 0.00311 seconds
Time Before: 0.00378 seconds
Time After: 0.00652 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00316 seconds
Time After: 0.00995 seconds
Time Taken: 0.00679 seconds
Time Before: 0.01180 seconds
Time After: 0.01219 seconds
Time Before: 0.01477 seconds
Time After: 0.01601 seconds
Time Before: 0.01118 seconds
Time After: 0.01619 seconds
Time Taken: 0.00502 seconds
Time Before: 0.02337 seconds
Time After: 0.02352 seconds
Time Before: 0.02529 seconds
Time After: 0.02667 seconds
Time Taken: 0.00137 seconds
End call of global.php: 0.029507160186768
Time Before: 0.03101 seconds
Time After: 0.03121 seconds
Time Before: 0.03385 seconds
Time After: 0.03536 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=132553', badlocation = 1
Time Before: 0.04836 seconds
Time After: 0.04865 seconds
Page generated in 0.047429084777832 seconds with 9 queries, spending 0.0085785388946533 doing MySQL queries and 0.038850545883179 doing PHP things.
