Time Before: 0.01417 seconds
Time After: 0.01817 seconds
Time Taken: 0.00400 seconds
Time Before: 0.01825 seconds
Time After: 0.01869 seconds
Time Before: 0.01892 seconds
Time After: 0.01909 seconds
Time Before: 0.01980 seconds
Time After: 0.02268 seconds
Time Taken: 0.00288 seconds
Time Before: 0.01915 seconds
Time After: 0.02688 seconds
Time Taken: 0.00773 seconds
Time Before: 0.03270 seconds
Time After: 0.03308 seconds
Time Before: 0.03563 seconds
Time After: 0.03686 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03200 seconds
Time After: 0.03706 seconds
Time Taken: 0.00506 seconds
Memory After: 2,261.703 KB
Time Before: 0.05156 seconds
Time After: 0.05173 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.06164 seconds
Time After: 0.06288 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.065057992935181
Time Before: 0.06973 seconds
Time After: 0.06990 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.07244 seconds
Time After: 0.07389 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=132599'
Time Before: 0.09312 seconds
Time After: 0.09343 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.091737031936646 seconds with 9 queries, spending 0.0084359645843506 doing MySQL queries and 0.083301067352295 doing PHP things.
