Time Before: 0.00636 seconds
Time After: 0.00813 seconds
Time Taken: 0.00177 seconds
Time Before: 0.00821 seconds
Time After: 0.00863 seconds
Time Before: 0.00888 seconds
Time After: 0.00903 seconds
Time Before: 0.01003 seconds
Time After: 0.01224 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00910 seconds
Time After: 0.01653 seconds
Time Taken: 0.00743 seconds
Time Before: 0.02018 seconds
Time After: 0.02060 seconds
Time Before: 0.02318 seconds
Time After: 0.02445 seconds
Time Before: 0.01947 seconds
Time After: 0.02470 seconds
Time Taken: 0.00523 seconds
Time Before: 0.04291 seconds
Time After: 0.04303 seconds
Time Before: 0.04974 seconds
Time After: 0.05099 seconds
Time Before: 0.05699 seconds
Time After: 0.05715 seconds
Time Before: 0.05954 seconds
Time After: 0.06099 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=132628', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.07809 seconds
Time After: 0.07837 seconds
