Time Before: 0.00249 seconds
Time After: 0.00314 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00324 seconds
Time After: 0.00373 seconds
Time Before: 0.00397 seconds
Time After: 0.00409 seconds
Time Before: 0.00498 seconds
Time After: 0.00713 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00414 seconds
Time After: 0.01173 seconds
Time Taken: 0.00759 seconds
Time Before: 0.01415 seconds
Time After: 0.01464 seconds
Time Before: 0.01637 seconds
Time After: 0.01867 seconds
Time Taken: 0.00231 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01354 seconds
Time After: 0.01884 seconds
Time Taken: 0.00530 seconds
Memory After: 2,261.703 KB
Time Before: 0.02480 seconds
Time After: 0.02496 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02704 seconds
Time After: 0.02829 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.029939889907837
Time Before: 0.03133 seconds
Time After: 0.03150 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03434 seconds
Time After: 0.03636 seconds
Time Taken: 0.00202 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=132691', badlocation = 1
Time Before: 0.05148 seconds
Time After: 0.05192 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.050488948822021 seconds with 9 queries, spending 0.0095944404602051 doing MySQL queries and 0.040894508361816 doing PHP things.
