Time Before: 0.03840 seconds
Time After: 0.04920 seconds
Time Taken: 0.01080 seconds
Time Before: 0.04931 seconds
Time After: 0.04970 seconds
Time Before: 0.04991 seconds
Time After: 0.05002 seconds
Time Before: 0.05078 seconds
Time After: 0.05321 seconds
Time Taken: 0.00243 seconds
Time Before: 0.05008 seconds
Time After: 0.05695 seconds
Time Taken: 0.00687 seconds
Time Before: 0.07041 seconds
Time After: 0.07080 seconds
Time Before: 0.07369 seconds
Time After: 0.07485 seconds
Time Taken: 0.00116 seconds
Time Before: 0.06962 seconds
Time After: 0.07504 seconds
Time Taken: 0.00541 seconds
Time Before: 0.13081 seconds
Time After: 0.13094 seconds
Time Before: 0.16411 seconds
Time After: 0.16543 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.16799306869507
Time Before: 0.18252 seconds
Time After: 0.18268 seconds
Time Before: 0.18519 seconds
Time After: 0.18663 seconds
SET lastactivity = 1783209054, location = '/forums/private.php?do=newpm&explain=1&u=132695'
Time Before: 0.20927 seconds
Time After: 0.20956 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
Page generated in 0.20816993713379 seconds with 9 queries, spending 0.0077998638153076 doing MySQL queries and 0.20037007331848 doing PHP things.
