Time Before: 0.00145 seconds
Time After: 0.00207 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00214 seconds
Time After: 0.00255 seconds
Time Before: 0.00280 seconds
Time After: 0.00295 seconds
Time Before: 0.00361 seconds
Time After: 0.00816 seconds
Time Taken: 0.00455 seconds
Time Before: 0.00299 seconds
Time After: 0.01285 seconds
Time Taken: 0.00985 seconds
Time Before: 0.01513 seconds
Time After: 0.01552 seconds
Time Before: 0.01804 seconds
Time After: 0.01928 seconds
Time Before: 0.01446 seconds
Time After: 0.01955 seconds
Time Taken: 0.00509 seconds
Time Before: 0.02506 seconds
Time After: 0.02523 seconds
Time Before: 0.02698 seconds
Time After: 0.02822 seconds
Time Before: 0.03098 seconds
Time After: 0.03115 seconds
Time Before: 0.03309 seconds
Time After: 0.03460 seconds
Time Taken: 0.00150 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=132722' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.05055 seconds
Time After: 0.05082 seconds
