Time Before: 0.00154 seconds
Time After: 0.00203 seconds
Time Before: 0.00210 seconds
Time After: 0.00258 seconds
Time Before: 0.00278 seconds
Time After: 0.00290 seconds
Time Before: 0.00365 seconds
Time After: 0.00574 seconds
Time Taken: 0.00210 seconds
Time Before: 0.00295 seconds
Time After: 0.00913 seconds
Time Taken: 0.00618 seconds
Time Before: 0.01118 seconds
Time After: 0.01156 seconds
Time Before: 0.01435 seconds
Time After: 0.01559 seconds
Time Before: 0.01062 seconds
Time After: 0.01577 seconds
Time Taken: 0.00515 seconds
Time Before: 0.02111 seconds
Time After: 0.02123 seconds
Time Before: 0.02313 seconds
Time After: 0.02467 seconds
Time Taken: 0.00154 seconds
Time Before: 0.02824 seconds
Time After: 0.02840 seconds
Time Before: 0.03140 seconds
Time After: 0.03282 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=132730', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04899 seconds
Time After: 0.04931 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
