Time Before: 0.00750 seconds
Time After: 0.01029 seconds
Time Taken: 0.00279 seconds
Time Before: 0.01039 seconds
Time After: 0.01082 seconds
Time Before: 0.01106 seconds
Time After: 0.01121 seconds
Time Before: 0.01199 seconds
Time After: 0.01432 seconds
Time Taken: 0.00232 seconds
Time Before: 0.01127 seconds
Time After: 0.01920 seconds
Time Taken: 0.00793 seconds
Time Before: 0.02526 seconds
Time After: 0.02568 seconds
Time Before: 0.02832 seconds
Time After: 0.03014 seconds
Time Taken: 0.00182 seconds
Time Before: 0.02454 seconds
Time After: 0.03036 seconds
Time Taken: 0.00582 seconds
Time Before: 0.03898 seconds
Time After: 0.03959 seconds
Time Taken: 0.00062 seconds
Time Before: 0.04457 seconds
Time After: 0.04583 seconds
End call of global.php: 0.048269033432007
Time Before: 0.05291 seconds
Time After: 0.05316 seconds
Time Before: 0.05605 seconds
Time After: 0.05753 seconds
SET lastactivity = 1789140302, location = '/forums/private.php?do=newpm&explain=1&u=132741'
Time Before: 0.07501 seconds
Time After: 0.07527 seconds
Page generated in 0.073662042617798 seconds with 9 queries, spending 0.0089991092681885 doing MySQL queries and 0.064662933349609 doing PHP things.
