Time Before: 0.00358 seconds
Time After: 0.00497 seconds
Time Taken: 0.00139 seconds
Time Before: 0.00507 seconds
Time After: 0.00558 seconds
Time Before: 0.00583 seconds
Time After: 0.00595 seconds
Time Before: 0.00662 seconds
Time After: 0.00882 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00600 seconds
Time After: 0.01236 seconds
Time Taken: 0.00636 seconds
Time Before: 0.01435 seconds
Time After: 0.01480 seconds
Time Before: 0.01790 seconds
Time After: 0.01910 seconds
Time Before: 0.01365 seconds
Time After: 0.01935 seconds
Time Taken: 0.00571 seconds
Time Before: 0.02516 seconds
Time After: 0.02533 seconds
Time Before: 0.02835 seconds
Time After: 0.02976 seconds
End call of global.php: 0.031426906585693
Time Before: 0.03292 seconds
Time After: 0.03310 seconds
Time Before: 0.03525 seconds
Time After: 0.03675 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=132789', badlocation = 1
Time Before: 0.05210 seconds
Time After: 0.05241 seconds
Page generated in 0.051162958145142 seconds with 9 queries, spending 0.0080325603485107 doing MySQL queries and 0.043130397796631 doing PHP things.
