Time Before: 0.00165 seconds
Time After: 0.00208 seconds
Time Before: 0.00216 seconds
Time After: 0.00260 seconds
Time Before: 0.00284 seconds
Time After: 0.00301 seconds
Time Before: 0.00367 seconds
Time After: 0.00648 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00306 seconds
Time After: 0.00984 seconds
Time Taken: 0.00678 seconds
Time Before: 0.01174 seconds
Time After: 0.01218 seconds
Time Before: 0.01463 seconds
Time After: 0.01602 seconds
Time Taken: 0.00138 seconds
Time Before: 0.01108 seconds
Time After: 0.01619 seconds
Time Taken: 0.00510 seconds
Time Before: 0.02104 seconds
Time After: 0.02124 seconds
Time Before: 0.02296 seconds
Time After: 0.02416 seconds
Time Before: 0.02684 seconds
Time After: 0.02697 seconds
Time Before: 0.02887 seconds
Time After: 0.03025 seconds
UPDATE session SET lastactivity = 1789118460, location = '/forums/private.php?do=newpm&explain=1&u=132825' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04242 seconds
Time After: 0.04272 seconds
