Time Before: 0.02503 seconds
Time After: 0.03604 seconds
Time Taken: 0.01101 seconds
Time Before: 0.03614 seconds
Time After: 0.03662 seconds
Time Before: 0.03694 seconds
Time After: 0.03711 seconds
Time Before: 0.03795 seconds
Time After: 0.04077 seconds
Time Taken: 0.00282 seconds
Time Before: 0.03718 seconds
Time After: 0.04498 seconds
Time Taken: 0.00780 seconds
Time Before: 0.05552 seconds
Time After: 0.05592 seconds
Time Before: 0.05852 seconds
Time After: 0.05970 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05371 seconds
Time After: 0.05995 seconds
Time Taken: 0.00624 seconds
Time Before: 0.09680 seconds
Time After: 0.09699 seconds
Time Before: 0.11807 seconds
Time After: 0.11934 seconds
Time Before: 0.13225 seconds
Time After: 0.13243 seconds
Time Before: 0.13497 seconds
Time After: 0.13640 seconds
UPDATE session SET lastactivity = 1782939878, location = '/forums/private.php?do=newpm&explain=1&u=132861' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.15581 seconds
Time After: 0.15609 seconds
