Time Before: 0.02010 seconds
Time After: 0.02722 seconds
Time Taken: 0.00711 seconds
Time Before: 0.02732 seconds
Time After: 0.02782 seconds
Time Before: 0.02808 seconds
Time After: 0.02827 seconds
Time Before: 0.02897 seconds
Time After: 0.03179 seconds
Time Taken: 0.00282 seconds
Time Before: 0.02832 seconds
Time After: 0.03672 seconds
Time Taken: 0.00839 seconds
Time Before: 0.04443 seconds
Time After: 0.04467 seconds
Time Before: 0.04693 seconds
Time After: 0.04816 seconds
Time Before: 0.04367 seconds
Time After: 0.04839 seconds
Time Taken: 0.00472 seconds
Time Before: 0.08343 seconds
Time After: 0.08362 seconds
Time Before: 0.10148 seconds
Time After: 0.10273 seconds
Time Before: 0.11094 seconds
Time After: 0.11112 seconds
Time Before: 0.11364 seconds
Time After: 0.11511 seconds
UPDATE session SET lastactivity = 1776632561, location = '/forums/private.php?do=newpm&explain=1&u=132864', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.13418 seconds
Time After: 0.13445 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
