Time Before: 0.00158 seconds
Time After: 0.00204 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00210 seconds
Time After: 0.00273 seconds
Time Taken: 0.00062 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00298 seconds
Time After: 0.00313 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00381 seconds
Time After: 0.00640 seconds
Time Taken: 0.00259 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00318 seconds
Time After: 0.00982 seconds
Time Taken: 0.00664 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01182 seconds
Time After: 0.01228 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01531 seconds
Time After: 0.01678 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01116 seconds
Time After: 0.01696 seconds
Time Taken: 0.00579 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02259 seconds
Time After: 0.02294 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02653 seconds
Time After: 0.02781 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
End call of global.php: 0.029463052749634
Time Before: 0.03085 seconds
Time After: 0.03106 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03346 seconds
Time After: 0.03677 seconds
Time Taken: 0.00331 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=132880', badlocation = 1
Time Before: 0.05280 seconds
Time After: 0.05312 seconds
Memory Before: 4,918.680 KB
Memory After: 4,918.906 KB
Page generated in 0.05190896987915 seconds with 9 queries, spending 0.010748863220215 doing MySQL queries and 0.041160106658936 doing PHP things.
