Time Before: 0.00375 seconds
Time After: 0.00531 seconds
Time Taken: 0.00156 seconds
Time Before: 0.00541 seconds
Time After: 0.00576 seconds
Time Before: 0.00604 seconds
Time After: 0.00616 seconds
Time Before: 0.00696 seconds
Time After: 0.00921 seconds
Time Taken: 0.00225 seconds
Time Before: 0.00622 seconds
Time After: 0.01380 seconds
Time Taken: 0.00758 seconds
Time Before: 0.01736 seconds
Time After: 0.01781 seconds
Time Before: 0.02065 seconds
Time After: 0.02192 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01607 seconds
Time After: 0.02220 seconds
Time Taken: 0.00613 seconds
Memory After: 2,261.703 KB
Time Before: 0.03045 seconds
Time After: 0.03058 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.03431 seconds
Time After: 0.03559 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.037256956100464
Time Before: 0.03882 seconds
Time After: 0.03895 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.04142 seconds
Time After: 0.04294 seconds
Time Taken: 0.00152 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=132894'
Time Before: 0.06002 seconds
Time After: 0.06040 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
Page generated in 0.058808088302612 seconds with 9 queries, spending 0.0078842639923096 doing MySQL queries and 0.050923824310303 doing PHP things.
