Time Before: 0.00282 seconds
Time After: 0.00350 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00359 seconds
Time After: 0.00402 seconds
Time Before: 0.00424 seconds
Time After: 0.00437 seconds
Time Before: 0.00529 seconds
Time After: 0.00790 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00444 seconds
Time After: 0.01356 seconds
Time Taken: 0.00912 seconds
Time Before: 0.01624 seconds
Time After: 0.01666 seconds
Time Before: 0.01843 seconds
Time After: 0.01974 seconds
Time Before: 0.01541 seconds
Time After: 0.01993 seconds
Time Taken: 0.00453 seconds
Time Before: 0.02515 seconds
Time After: 0.02527 seconds
Time Before: 0.02716 seconds
Time After: 0.02848 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03226 seconds
Time After: 0.03242 seconds
Time Before: 0.03447 seconds
Time After: 0.03594 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=132938' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.05581 seconds
Time After: 0.05613 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
