Time Before: 0.00169 seconds
Time After: 0.00233 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00240 seconds
Time After: 0.00280 seconds
Time Before: 0.00308 seconds
Time After: 0.00321 seconds
Time Before: 0.00431 seconds
Time After: 0.00738 seconds
Time Taken: 0.00307 seconds
Time Before: 0.00325 seconds
Time After: 0.01128 seconds
Time Taken: 0.00802 seconds
Time Before: 0.01351 seconds
Time After: 0.01388 seconds
Time Before: 0.01657 seconds
Time After: 0.01777 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01295 seconds
Time After: 0.01795 seconds
Time Taken: 0.00501 seconds
Memory After: 2,261.820 KB
Time Before: 0.02555 seconds
Time After: 0.02592 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02782 seconds
Time After: 0.02906 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03173 seconds
Time After: 0.03185 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03375 seconds
Time After: 0.03518 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789111363, location = '/forums/private.php?do=newpm&explain=1&u=132979', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04837 seconds
Time After: 0.04866 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
