Time Before: 0.00136 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00246 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00271 seconds
Time After: 0.00283 seconds
Time Before: 0.00358 seconds
Time After: 0.00620 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00288 seconds
Time After: 0.00956 seconds
Time Taken: 0.00668 seconds
Time Before: 0.01168 seconds
Time After: 0.01224 seconds
Time Before: 0.01547 seconds
Time After: 0.01677 seconds
Time Before: 0.01095 seconds
Time After: 0.01696 seconds
Time Taken: 0.00601 seconds
Time Before: 0.02229 seconds
Time After: 0.02249 seconds
Time Before: 0.02529 seconds
Time After: 0.02664 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.028362989425659
Time Before: 0.02999 seconds
Time After: 0.03022 seconds
Time Before: 0.03232 seconds
Time After: 0.03388 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=133000'
Time Before: 0.04674 seconds
Time After: 0.04712 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
Page generated in 0.045793056488037 seconds with 9 queries, spending 0.0088939666748047 doing MySQL queries and 0.036899089813232 doing PHP things.
