Time Before: 0.01794 seconds
Time After: 0.02428 seconds
Time Taken: 0.00634 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02445 seconds
Time After: 0.02495 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02524 seconds
Time After: 0.02538 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02640 seconds
Time After: 0.02863 seconds
Time Taken: 0.00223 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02549 seconds
Time After: 0.03311 seconds
Time Taken: 0.00763 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04089 seconds
Time After: 0.04129 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04279 seconds
Time After: 0.04401 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04012 seconds
Time After: 0.04425 seconds
Time Taken: 0.00412 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.07542 seconds
Time After: 0.07556 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.12057 seconds
Time After: 0.12181 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.14473 seconds
Time After: 0.14491 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.15001 seconds
Time After: 0.15144 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772920980, location = '/forums/private.php?do=newpm&explain=1&u=133010' WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.17389 seconds
Time After: 0.17414 seconds
Memory Before: 5,997.945 KB
Memory After: 5,998.164 KB
