Time Before: 0.00276 seconds
Time After: 0.00333 seconds
Time Taken: 0.00057 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00340 seconds
Time After: 0.00381 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00403 seconds
Time After: 0.00414 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00479 seconds
Time After: 0.00696 seconds
Time Taken: 0.00217 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00419 seconds
Time After: 0.01195 seconds
Time Taken: 0.00776 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01382 seconds
Time After: 0.01419 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01657 seconds
Time After: 0.01771 seconds
Time Taken: 0.00114 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01321 seconds
Time After: 0.01791 seconds
Time Taken: 0.00470 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02476 seconds
Time After: 0.02490 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.03344 seconds
Time After: 0.03467 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.036490201950073
Time Before: 0.04303 seconds
Time After: 0.04319 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.04681 seconds
Time After: 0.04934 seconds
Time Taken: 0.00254 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=133011', badlocation = 1
WHERE sessionhash = '2551b86e31a021bec76dc32607bdb915'
Time Before: 0.06435 seconds
Time After: 0.06465 seconds
Memory Before: 5,998.641 KB
Memory After: 5,998.859 KB
Page generated in 0.063313007354736 seconds with 9 queries, spending 0.0085651874542236 doing MySQL queries and 0.054747819900513 doing PHP things.
