Time Before: 0.01211 seconds
Time After: 0.01476 seconds
Time Taken: 0.00265 seconds
Time Before: 0.01484 seconds
Time After: 0.01529 seconds
Time Before: 0.01553 seconds
Time After: 0.01569 seconds
Time Before: 0.01649 seconds
Time After: 0.01908 seconds
Time Taken: 0.00259 seconds
Time Before: 0.01577 seconds
Time After: 0.02345 seconds
Time Taken: 0.00768 seconds
Time Before: 0.02923 seconds
Time After: 0.02962 seconds
Time Before: 0.03203 seconds
Time After: 0.03325 seconds
Time Before: 0.02857 seconds
Time After: 0.03349 seconds
Time Taken: 0.00492 seconds
Time Before: 0.05754 seconds
Time After: 0.05772 seconds
Time Before: 0.06688 seconds
Time After: 0.06810 seconds
End call of global.php: 0.070432901382446
Time Before: 0.07484 seconds
Time After: 0.07501 seconds
Time Before: 0.07759 seconds
Time After: 0.07900 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=133030'
Time Before: 0.09706 seconds
Time After: 0.09735 seconds
Page generated in 0.095958948135376 seconds with 9 queries, spending 0.0080945491790771 doing MySQL queries and 0.087864398956299 doing PHP things.
