Time Before: 0.00188 seconds
Time After: 0.00268 seconds
Time Taken: 0.00081 seconds
Time Before: 0.00279 seconds
Time After: 0.00346 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00377 seconds
Time After: 0.00393 seconds
Time Before: 0.00485 seconds
Time After: 0.00808 seconds
Time Taken: 0.00323 seconds
Time Before: 0.00401 seconds
Time After: 0.01246 seconds
Time Taken: 0.00845 seconds
Time Before: 0.01510 seconds
Time After: 0.01573 seconds
Time Taken: 0.00063 seconds
Time Before: 0.01845 seconds
Time After: 0.01998 seconds
Time Taken: 0.00153 seconds
Time Before: 0.01439 seconds
Time After: 0.02019 seconds
Time Taken: 0.00580 seconds
Time Before: 0.02566 seconds
Time After: 0.02582 seconds
Time Before: 0.02778 seconds
Time After: 0.02916 seconds
Time Taken: 0.00138 seconds
Time Before: 0.03218 seconds
Time After: 0.03237 seconds
Time Before: 0.03445 seconds
Time After: 0.03597 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=133060' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.04941 seconds
Time After: 0.04967 seconds
